Time Before: 0.01100 seconds
Time After: 0.01597 seconds
Time Taken: 0.00497 seconds
Time Before: 0.01608 seconds
Time After: 0.01651 seconds
Time Before: 0.01681 seconds
Time After: 0.01695 seconds
Time Before: 0.01775 seconds
Time After: 0.02017 seconds
Time Taken: 0.00241 seconds
Time Before: 0.01702 seconds
Time After: 0.02445 seconds
Time Taken: 0.00742 seconds
Time Before: 0.02846 seconds
Time After: 0.02887 seconds
Time Before: 0.03139 seconds
Time After: 0.03255 seconds
Time Taken: 0.00116 seconds
Time Before: 0.02777 seconds
Time After: 0.03276 seconds
Time Taken: 0.00499 seconds
Time Before: 0.05713 seconds
Time After: 0.05727 seconds
Time Before: 0.07046 seconds
Time After: 0.07172 seconds
End call of global.php: 0.073854923248291
Time Before: 0.07825 seconds
Time After: 0.07846 seconds
Time Before: 0.08051 seconds
Time After: 0.08202 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=43238'
Time Before: 0.09592 seconds
Time After: 0.09633 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
Page generated in 0.094999074935913 seconds with 9 queries, spending 0.0080902576446533 doing MySQL queries and 0.08690881729126 doing PHP things.
