Time Before: 0.00144 seconds
Time After: 0.00191 seconds
Time Before: 0.00198 seconds
Time After: 0.00242 seconds
Time Before: 0.00270 seconds
Time After: 0.00284 seconds
Time Before: 0.00345 seconds
Time After: 0.00577 seconds
Time Taken: 0.00232 seconds
Time Before: 0.00288 seconds
Time After: 0.01051 seconds
Time Taken: 0.00763 seconds
Time Before: 0.01281 seconds
Time After: 0.01315 seconds
Time Before: 0.01526 seconds
Time After: 0.01647 seconds
Time Before: 0.01212 seconds
Time After: 0.01670 seconds
Time Taken: 0.00459 seconds
Time Before: 0.02449 seconds
Time After: 0.02462 seconds
Time Before: 0.02730 seconds
Time After: 0.02857 seconds
Time Before: 0.03232 seconds
Time After: 0.03252 seconds
Time Before: 0.03507 seconds
Time After: 0.03654 seconds
UPDATE session SET lastactivity = 1788919976, location = '/forums/private.php?do=newpm&explain=1&u=43273' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05031 seconds
Time After: 0.05065 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
