Time Before: 0.01910 seconds
Time After: 0.02516 seconds
Time Taken: 0.00606 seconds
Time Before: 0.02524 seconds
Time After: 0.02575 seconds
Time Before: 0.02605 seconds
Time After: 0.02618 seconds
Time Before: 0.02714 seconds
Time After: 0.02955 seconds
Time Taken: 0.00241 seconds
Time Before: 0.02625 seconds
Time After: 0.03453 seconds
Time Taken: 0.00828 seconds
Time Before: 0.04435 seconds
Time After: 0.04482 seconds
Time Before: 0.04803 seconds
Time After: 0.04923 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04338 seconds
Time After: 0.04943 seconds
Memory After: 2,261.836 KB
Time Before: 0.07788 seconds
Time After: 0.07802 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.09437 seconds
Time After: 0.09570 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.10532 seconds
Time After: 0.10548 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.10813 seconds
Time After: 0.10963 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789088663, location = '/forums/private.php?do=newpm&explain=1&u=43298' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.12852 seconds
Time After: 0.12880 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
