Time Before: 0.04376 seconds
Time After: 0.05545 seconds
Time Taken: 0.01169 seconds
Time Before: 0.05554 seconds
Time After: 0.05618 seconds
Time Taken: 0.00064 seconds
Time Before: 0.05646 seconds
Time After: 0.05668 seconds
Time Before: 0.05753 seconds
Time After: 0.05993 seconds
Time Taken: 0.00239 seconds
Time Before: 0.05673 seconds
Time After: 0.06444 seconds
Time Taken: 0.00771 seconds
Time Before: 0.07856 seconds
Time After: 0.07884 seconds
Time Before: 0.08035 seconds
Time After: 0.08161 seconds
Time Before: 0.07781 seconds
Time After: 0.08182 seconds
Time Taken: 0.00401 seconds
Time Before: 0.13449 seconds
Time After: 0.13471 seconds
Time Before: 0.16902 seconds
Time After: 0.17027 seconds
Time Before: 0.18565 seconds
Time After: 0.18581 seconds
Time Before: 0.18836 seconds
Time After: 0.18984 seconds
UPDATE session SET lastactivity = 1784870407, location = '/forums/private.php?do=newpm&explain=1&u=43921' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.21191 seconds
Time After: 0.21227 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
