Time Before: 0.00561 seconds
Time After: 0.00961 seconds
Time Taken: 0.00400 seconds
Time Before: 0.00972 seconds
Time After: 0.01026 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01050 seconds
Time After: 0.01064 seconds
Time Before: 0.01146 seconds
Time After: 0.01387 seconds
Time Taken: 0.00240 seconds
Time Before: 0.01071 seconds
Time After: 0.01860 seconds
Time Taken: 0.00789 seconds
Time Before: 0.02227 seconds
Time After: 0.02269 seconds
Time Before: 0.02536 seconds
Time After: 0.02659 seconds
Time Before: 0.02148 seconds
Time After: 0.02681 seconds
Time Taken: 0.00533 seconds
Time Before: 0.04084 seconds
Time After: 0.04096 seconds
Time Before: 0.04563 seconds
Time After: 0.04693 seconds
End call of global.php: 0.049477100372314
Time Before: 0.05175 seconds
Time After: 0.05189 seconds
Time Before: 0.05458 seconds
Time After: 0.05612 seconds
Time Taken: 0.00154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=43978'
Time Before: 0.07714 seconds
Time After: 0.07744 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.07600998878479 seconds with 9 queries, spending 0.0081262588500977 doing MySQL queries and 0.067883729934692 doing PHP things.
