Time Before: 0.03258 seconds
Time After: 0.04011 seconds
Time Taken: 0.00754 seconds
Time Before: 0.04022 seconds
Time After: 0.04067 seconds
Time Before: 0.04101 seconds
Time After: 0.04115 seconds
Time Before: 0.04203 seconds
Time After: 0.04429 seconds
Time Taken: 0.00226 seconds
Time Before: 0.04120 seconds
Time After: 0.04874 seconds
Time Before: 0.06297 seconds
Time After: 0.06343 seconds
Time Before: 0.06668 seconds
Time After: 0.06788 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.06205 seconds
Time After: 0.06811 seconds
Time Taken: 0.00606 seconds
Memory After: 2,261.836 KB
Time Before: 0.10523 seconds
Time After: 0.10537 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.13988 seconds
Time After: 0.14215 seconds
Time Taken: 0.00227 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.15993 seconds
Time After: 0.16013 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.16267 seconds
Time After: 0.16414 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789019014, location = '/forums/private.php?do=newpm&explain=1&u=43985' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.18475 seconds
Time After: 0.18504 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
