Time Before: 0.00302 seconds
Time After: 0.00389 seconds
Time Taken: 0.00088 seconds
Time Before: 0.00396 seconds
Time After: 0.00464 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00493 seconds
Time After: 0.00507 seconds
Time Before: 0.00591 seconds
Time After: 0.01065 seconds
Time Taken: 0.00474 seconds
Time Before: 0.00512 seconds
Time After: 0.01408 seconds
Time Taken: 0.00897 seconds
Time Before: 0.01634 seconds
Time After: 0.01670 seconds
Time Before: 0.01917 seconds
Time After: 0.02060 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01580 seconds
Time After: 0.02078 seconds
Time Taken: 0.00498 seconds
Memory After: 2,261.719 KB
Time Before: 0.02622 seconds
Time After: 0.02638 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02878 seconds
Time After: 0.03006 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.032888889312744
Time Before: 0.03440 seconds
Time After: 0.03486 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03795 seconds
Time After: 0.03937 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=43992'
Time Before: 0.05606 seconds
Time After: 0.05682 seconds
Time Taken: 0.00076 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.054725885391235 seconds with 9 queries, spending 0.011430263519287 doing MySQL queries and 0.043295621871948 doing PHP things.
