Time Before: 0.02067 seconds
Time After: 0.02738 seconds
Time Taken: 0.00671 seconds
Time Before: 0.02749 seconds
Time After: 0.02791 seconds
Time Before: 0.02815 seconds
Time After: 0.02829 seconds
Time Before: 0.02918 seconds
Time After: 0.03161 seconds
Time Taken: 0.00243 seconds
Time Before: 0.02835 seconds
Time After: 0.03596 seconds
Time Taken: 0.00761 seconds
Time Before: 0.04397 seconds
Time After: 0.04439 seconds
Time Before: 0.04779 seconds
Time After: 0.04905 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04323 seconds
Time After: 0.04927 seconds
Time Taken: 0.00604 seconds
Memory After: 2,261.836 KB
Time Before: 0.07534 seconds
Time After: 0.07550 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.19596 seconds
Time After: 0.19723 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.20631 seconds
Time After: 0.20646 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.20936 seconds
Time After: 0.21089 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789042004, location = '/forums/private.php?do=newpm&explain=1&u=4403', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.22806 seconds
Time After: 0.22845 seconds
Memory Before: 4,287.867 KB
Memory After: 4,288.078 KB
