Time Before: 0.00143 seconds
Time After: 0.00200 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00207 seconds
Time After: 0.00251 seconds
Time Before: 0.00269 seconds
Time After: 0.00280 seconds
Time Before: 0.00346 seconds
Time After: 0.00689 seconds
Time Taken: 0.00343 seconds
Time Before: 0.00285 seconds
Time After: 0.01120 seconds
Time Taken: 0.00835 seconds
Time Before: 0.01343 seconds
Time After: 0.01381 seconds
Time Before: 0.01644 seconds
Time After: 0.01769 seconds
Time Before: 0.01272 seconds
Time After: 0.01789 seconds
Time Taken: 0.00517 seconds
Time Before: 0.02401 seconds
Time After: 0.02414 seconds
Time Before: 0.02687 seconds
Time After: 0.02813 seconds
End call of global.php: 0.030498027801514
Time Before: 0.03221 seconds
Time After: 0.03234 seconds
Time Before: 0.03459 seconds
Time After: 0.03603 seconds
SET lastactivity = 1784779177, location = '/forums/private.php?do=newpm&explain=1&u=44106'
Time Before: 0.04910 seconds
Time After: 0.04942 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.048145055770874 seconds with 9 queries, spending 0.0089049339294434 doing MySQL queries and 0.039240121841431 doing PHP things.
