Time Before: 0.02561 seconds
Time After: 0.03364 seconds
Time Taken: 0.00803 seconds
Time Before: 0.03373 seconds
Time After: 0.03421 seconds
Time Before: 0.03452 seconds
Time After: 0.03470 seconds
Time Before: 0.03543 seconds
Time After: 0.03812 seconds
Time Taken: 0.00269 seconds
Time Before: 0.03476 seconds
Time After: 0.04201 seconds
Time Taken: 0.00725 seconds
Time Before: 0.05005 seconds
Time After: 0.05026 seconds
Time Before: 0.05275 seconds
Time After: 0.05402 seconds
Time Before: 0.04931 seconds
Time After: 0.05422 seconds
Time Taken: 0.00491 seconds
Time Before: 0.08656 seconds
Time After: 0.08671 seconds
Time Before: 0.18398 seconds
Time After: 0.18525 seconds
End call of global.php: 0.18820905685425
Time Before: 0.19660 seconds
Time After: 0.19680 seconds
Time Before: 0.19911 seconds
Time After: 0.20059 seconds
SET lastactivity = 1783204202, location = '/forums/private.php?do=newpm&explain=1&u=44190', badlocation = 1
Time Before: 0.21575 seconds
Time After: 0.21602 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
Page generated in 0.21482110023499 seconds with 9 queries, spending 0.0081958770751953 doing MySQL queries and 0.20662522315979 doing PHP things.
