Time Before: 0.00909 seconds
Time After: 0.01132 seconds
Time Taken: 0.00223 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01142 seconds
Time After: 0.01237 seconds
Time Taken: 0.00095 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.01284 seconds
Time After: 0.01303 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.01384 seconds
Time After: 0.01630 seconds
Time Taken: 0.00247 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.01310 seconds
Time After: 0.02080 seconds
Time Taken: 0.00771 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.02379 seconds
Time After: 0.02420 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.02684 seconds
Time After: 0.02843 seconds
Time Taken: 0.00159 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.02307 seconds
Time After: 0.02872 seconds
Time Taken: 0.00564 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.04503 seconds
Time After: 0.04520 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.07246 seconds
Time After: 0.07374 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.09076 seconds
Time After: 0.09097 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.09552 seconds
Time After: 0.09703 seconds
Time Taken: 0.00151 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1772519332, location = '/forums/private.php?do=newpm&explain=1&u=44193' WHERE sessionhash = '4107984102e2914075bf6bfb65da9afe'
Time Before: 0.12181 seconds
Time After: 0.13662 seconds
Time Taken: 0.01481 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
