Time Before: 0.00141 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00244 seconds
Time Before: 0.00268 seconds
Time After: 0.00283 seconds
Time Before: 0.00355 seconds
Time After: 0.00639 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00288 seconds
Time After: 0.00983 seconds
Time Taken: 0.00695 seconds
Time Before: 0.01168 seconds
Time After: 0.01209 seconds
Time Before: 0.01533 seconds
Time After: 0.01652 seconds
Time Before: 0.01109 seconds
Time After: 0.01672 seconds
Time Taken: 0.00563 seconds
Time Before: 0.02269 seconds
Time After: 0.02286 seconds
Time Before: 0.02475 seconds
Time After: 0.02695 seconds
Time Taken: 0.00220 seconds
End call of global.php: 0.028701782226562
Time Before: 0.03031 seconds
Time After: 0.03046 seconds
Time Before: 0.03255 seconds
Time After: 0.03396 seconds
SET lastactivity = 1788969319, location = '/forums/private.php?do=newpm&explain=1&u=44240'
Time Before: 0.04641 seconds
Time After: 0.04682 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.04551100730896 seconds with 9 queries, spending 0.0093667507171631 doing MySQL queries and 0.036144256591797 doing PHP things.
