Time Before: 0.00144 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00231 seconds
Time Before: 0.00249 seconds
Time After: 0.00263 seconds
Time Before: 0.00328 seconds
Time After: 0.00565 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00267 seconds
Time After: 0.01105 seconds
Time Taken: 0.00838 seconds
Time Before: 0.01300 seconds
Time After: 0.01334 seconds
Time Before: 0.01573 seconds
Time After: 0.01691 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01241 seconds
Time After: 0.01714 seconds
Time Taken: 0.00473 seconds
Time Before: 0.02378 seconds
Time After: 0.02392 seconds
Time Before: 0.02614 seconds
Time After: 0.02736 seconds
Time Before: 0.03022 seconds
Time After: 0.03037 seconds
Time Before: 0.03241 seconds
Time After: 0.03388 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=44284' WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.04632 seconds
Time After: 0.04656 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
