Time Before: 0.00142 seconds
Time After: 0.00191 seconds
Time Before: 0.00197 seconds
Time After: 0.00236 seconds
Time Before: 0.00262 seconds
Time After: 0.00277 seconds
Time Before: 0.00349 seconds
Time After: 0.00663 seconds
Time Taken: 0.00314 seconds
Time Before: 0.00282 seconds
Time After: 0.01001 seconds
Time Taken: 0.00719 seconds
Time Before: 0.01186 seconds
Time After: 0.01236 seconds
Time Before: 0.01486 seconds
Time After: 0.01613 seconds
Time Before: 0.01121 seconds
Time After: 0.01630 seconds
Time Taken: 0.00508 seconds
Time Before: 0.02155 seconds
Time After: 0.02173 seconds
Time Before: 0.02390 seconds
Time After: 0.02517 seconds
End call of global.php: 0.026885032653809
Time Before: 0.02812 seconds
Time After: 0.02827 seconds
Time Before: 0.03029 seconds
Time After: 0.03171 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=44320'
Time Before: 0.04442 seconds
Time After: 0.04469 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.043505191802979 seconds with 9 queries, spending 0.0087299346923828 doing MySQL queries and 0.034775257110596 doing PHP things.
