Time Before: 0.00146 seconds
Time After: 0.00207 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00213 seconds
Time After: 0.00249 seconds
Time Before: 0.00266 seconds
Time After: 0.00286 seconds
Time Before: 0.00369 seconds
Time After: 0.00651 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00294 seconds
Time After: 0.01118 seconds
Time Taken: 0.00824 seconds
Time Before: 0.01334 seconds
Time After: 0.01380 seconds
Time Before: 0.01657 seconds
Time After: 0.01797 seconds
Time Taken: 0.00140 seconds
Time Before: 0.01272 seconds
Time After: 0.01820 seconds
Time Taken: 0.00548 seconds
Time Before: 0.02615 seconds
Time After: 0.02629 seconds
Time Before: 0.02877 seconds
Time After: 0.03007 seconds
End call of global.php: 0.032706022262573
Time Before: 0.03456 seconds
Time After: 0.03487 seconds
Time Before: 0.03796 seconds
Time After: 0.03940 seconds
SET lastactivity = 1772817902, location = '/forums/private.php?do=newpm&explain=1&u=44337'
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.05600 seconds
Time After: 0.05632 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.054573059082031 seconds with 9 queries, spending 0.0087580680847168 doing MySQL queries and 0.045814990997314 doing PHP things.
