Time Before: 0.03255 seconds
Time After: 0.03914 seconds
Time Taken: 0.00659 seconds
Time Before: 0.03924 seconds
Time After: 0.03965 seconds
Time Before: 0.03991 seconds
Time After: 0.04005 seconds
Time Before: 0.04088 seconds
Time After: 0.04296 seconds
Time Taken: 0.00208 seconds
Time Before: 0.04011 seconds
Time After: 0.04674 seconds
Time Taken: 0.00664 seconds
Time Before: 0.05519 seconds
Time After: 0.05560 seconds
Time Before: 0.05717 seconds
Time After: 0.05889 seconds
Time Taken: 0.00173 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.05456 seconds
Time After: 0.05915 seconds
Time Taken: 0.00458 seconds
Memory After: 2,261.836 KB
Time Before: 0.11332 seconds
Time After: 0.11346 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.24298 seconds
Time After: 0.24425 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.24623489379883
Time Before: 0.25903 seconds
Time After: 0.25932 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.26186 seconds
Time After: 0.26337 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789015799, location = '/forums/private.php?do=newpm&explain=1&u=44391'
Time Before: 0.28223 seconds
Time After: 0.28255 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.28120183944702 seconds with 9 queries, spending 0.0082933902740479 doing MySQL queries and 0.27290844917297 doing PHP things.
