Time Before: 0.00139 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00250 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00276 seconds
Time After: 0.00290 seconds
Time Before: 0.00377 seconds
Time After: 0.00823 seconds
Time Taken: 0.00446 seconds
Time Before: 0.00295 seconds
Time After: 0.01341 seconds
Time Taken: 0.01046 seconds
Time Before: 0.01577 seconds
Time After: 0.01597 seconds
Time Before: 0.01804 seconds
Time After: 0.01925 seconds
Time Before: 0.01501 seconds
Time After: 0.01948 seconds
Time Taken: 0.00447 seconds
Time Before: 0.02468 seconds
Time After: 0.02488 seconds
Time Before: 1.90340 seconds
Time After: 1.90663 seconds
Time Taken: 0.00323 seconds
Time Before: 1.91768 seconds
Time After: 1.91787 seconds
Time Before: 1.92081 seconds
Time After: 1.92242 seconds
Time Taken: 0.00161 seconds
UPDATE session SET lastactivity = 1788905790, location = '/forums/private.php?do=newpm&explain=1&u=44490', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 1.94046 seconds
Time After: 1.94125 seconds
Time Taken: 0.00079 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
