Time Before: 0.01039 seconds
Time After: 0.01538 seconds
Time Taken: 0.00499 seconds
Time Before: 0.01549 seconds
Time After: 0.01587 seconds
Time Before: 0.01608 seconds
Time After: 0.01619 seconds
Time Taken: 0.00010 seconds
Time Before: 0.01692 seconds
Time After: 0.01883 seconds
Time Taken: 0.00190 seconds
Time Before: 0.01625 seconds
Time After: 0.02457 seconds
Time Taken: 0.00832 seconds
Time Before: 0.03165 seconds
Time After: 0.03202 seconds
Time Before: 0.03461 seconds
Time After: 0.03651 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03087 seconds
Time After: 0.03681 seconds
Time Taken: 0.00595 seconds
Memory After: 2,261.719 KB
Time Before: 0.04758 seconds
Time After: 0.04783 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.05964 seconds
Time After: 0.06089 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.06808 seconds
Time After: 0.06826 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.07186 seconds
Time After: 0.07346 seconds
Time Taken: 0.00160 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=44503', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.09136 seconds
Time After: 0.09164 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
