Time Before: 0.01519 seconds
Time After: 0.01801 seconds
Time Taken: 0.00282 seconds
Time Before: 0.01810 seconds
Time After: 0.01863 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01889 seconds
Time After: 0.01903 seconds
Time Before: 0.01987 seconds
Time After: 0.02234 seconds
Time Taken: 0.00247 seconds
Time Before: 0.01911 seconds
Time After: 0.02670 seconds
Time Taken: 0.00759 seconds
Time Before: 0.03035 seconds
Time After: 0.03095 seconds
Time Taken: 0.00060 seconds
Time Before: 0.03353 seconds
Time After: 0.03475 seconds
Time Before: 0.02964 seconds
Time After: 0.03496 seconds
Time Taken: 0.00532 seconds
Time Before: 0.05713 seconds
Time After: 0.05728 seconds
Time Before: 0.06445 seconds
Time After: 0.06585 seconds
Time Taken: 0.00140 seconds
Time Before: 0.07288 seconds
Time After: 0.07308 seconds
Time Before: 0.07650 seconds
Time After: 0.07793 seconds
UPDATE session SET lastactivity = 1784775713, location = '/forums/private.php?do=newpm&explain=1&u=44689' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.09431 seconds
Time After: 0.09455 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
