Time Before: 0.01799 seconds
Time After: 0.02614 seconds
Time Taken: 0.00814 seconds
Time Before: 0.02625 seconds
Time After: 0.02673 seconds
Time Before: 0.02697 seconds
Time After: 0.02712 seconds
Time Before: 0.02802 seconds
Time After: 0.03020 seconds
Time Taken: 0.00218 seconds
Time Before: 0.02727 seconds
Time After: 0.03447 seconds
Time Taken: 0.00720 seconds
Time Before: 0.04407 seconds
Time After: 0.04446 seconds
Time Before: 0.04705 seconds
Time After: 0.04827 seconds
Time Before: 0.04331 seconds
Time After: 0.04852 seconds
Time Taken: 0.00521 seconds
Time Before: 0.07099 seconds
Time After: 0.07115 seconds
Time Before: 0.17516 seconds
Time After: 0.17639 seconds
Time Before: 0.18829 seconds
Time After: 0.18846 seconds
Time Before: 0.19116 seconds
Time After: 0.19256 seconds
Time Taken: 0.00140 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=44758' WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.21012 seconds
Time After: 0.22982 seconds
Time Taken: 0.01970 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
