Time Before: 0.00525 seconds
Time After: 0.00834 seconds
Time Taken: 0.00310 seconds
Time Before: 0.00845 seconds
Time After: 0.00941 seconds
Time Taken: 0.00096 seconds
Time Before: 0.00964 seconds
Time After: 0.00982 seconds
Time Before: 0.01064 seconds
Time After: 0.01359 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00987 seconds
Time After: 0.01828 seconds
Time Taken: 0.00841 seconds
Time Before: 0.02278 seconds
Time After: 0.02318 seconds
Time Before: 0.02647 seconds
Time After: 0.02784 seconds
Time Taken: 0.00137 seconds
Time Before: 0.02208 seconds
Time After: 0.02808 seconds
Time Taken: 0.00601 seconds
Time Before: 0.04383 seconds
Time After: 0.04396 seconds
Time Before: 0.05020 seconds
Time After: 0.05167 seconds
Time Before: 0.05675 seconds
Time After: 0.05692 seconds
Time Before: 0.05956 seconds
Time After: 0.06131 seconds
Time Taken: 0.00175 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=44778' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.07839 seconds
Time After: 0.07868 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
