Time Before: 0.01786 seconds
Time After: 0.02281 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02292 seconds
Time After: 0.02338 seconds
Time Before: 0.02363 seconds
Time After: 0.02382 seconds
Time Before: 0.02473 seconds
Time After: 0.02784 seconds
Time Taken: 0.00311 seconds
Time Before: 0.02389 seconds
Time After: 0.03250 seconds
Time Taken: 0.00861 seconds
Time Before: 0.03815 seconds
Time After: 0.03861 seconds
Time Before: 0.04196 seconds
Time After: 0.04369 seconds
Time Taken: 0.00173 seconds
Time Before: 0.03735 seconds
Time After: 0.04399 seconds
Time Taken: 0.00664 seconds
Time Before: 0.07604 seconds
Time After: 0.07623 seconds
Time Before: 0.09882 seconds
Time After: 0.10027 seconds
End call of global.php: 0.10265302658081
Time Before: 0.10760 seconds
Time After: 0.10776 seconds
Time Before: 0.11058 seconds
Time After: 0.11202 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=44856'
Time Before: 0.13097 seconds
Time After: 0.13167 seconds
Time Taken: 0.00070 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.12952899932861 seconds with 9 queries, spending 0.0098986625671387 doing MySQL queries and 0.11963033676147 doing PHP things.
