Time Before: 0.00579 seconds
Time After: 0.00931 seconds
Time Taken: 0.00352 seconds
Time Before: 0.00940 seconds
Time After: 0.00978 seconds
Time Before: 0.01004 seconds
Time After: 0.01016 seconds
Time Before: 0.01095 seconds
Time After: 0.01338 seconds
Time Taken: 0.00243 seconds
Time Before: 0.01025 seconds
Time After: 0.01785 seconds
Time Taken: 0.00760 seconds
Time Before: 0.02363 seconds
Time After: 0.02405 seconds
Time Before: 0.02682 seconds
Time After: 0.02810 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02291 seconds
Time After: 0.02834 seconds
Time Taken: 0.00543 seconds
Memory After: 2,261.836 KB
Time Before: 0.04566 seconds
Time After: 0.04579 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05441 seconds
Time After: 0.05569 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.057504892349243
Time Before: 0.06395 seconds
Time After: 0.06409 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06630 seconds
Time After: 0.06784 seconds
Time Taken: 0.00154 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789058181, location = '/forums/private.php?do=newpm&explain=1&u=44864'
Time Before: 0.08366 seconds
Time After: 0.08436 seconds
Time Taken: 0.00071 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.082528829574585 seconds with 9 queries, spending 0.0084259510040283 doing MySQL queries and 0.074102878570557 doing PHP things.
