Time Before: 0.00202 seconds
Time After: 0.00261 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00271 seconds
Time After: 0.00314 seconds
Time Before: 0.00344 seconds
Time After: 0.00356 seconds
Time Before: 0.00450 seconds
Time After: 0.00720 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00364 seconds
Time After: 0.01194 seconds
Time Taken: 0.00830 seconds
Time Before: 0.01424 seconds
Time After: 0.01478 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01781 seconds
Time After: 0.01906 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01346 seconds
Time After: 0.01925 seconds
Time Taken: 0.00579 seconds
Memory After: 2,261.719 KB
Time Before: 0.02458 seconds
Time After: 0.02470 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02699 seconds
Time After: 0.02824 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.030316829681396
Time Before: 0.03218 seconds
Time After: 0.03241 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03452 seconds
Time After: 0.03594 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=44902', badlocation = 1
Time Before: 0.04840 seconds
Time After: 0.04866 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.047482013702393 seconds with 9 queries, spending 0.0083205699920654 doing MySQL queries and 0.039161443710327 doing PHP things.
