Time Before: 0.00970 seconds
Time After: 0.01159 seconds
Time Taken: 0.00190 seconds
Memory Before: 532.906 KB
Memory After: 558.023 KB
Time Before: 0.01167 seconds
Time After: 0.01212 seconds
Memory Before: 557.961 KB
Memory After: 558.969 KB
Time Before: 0.01237 seconds
Time After: 0.01253 seconds
Memory Before: 559.523 KB
Memory After: 560.047 KB
Time Before: 0.01340 seconds
Time After: 0.01557 seconds
Time Taken: 0.00217 seconds
Memory Before: 562.648 KB
Memory After: 563.570 KB
Time Before: 0.01261 seconds
Time After: 0.02046 seconds
Time Taken: 0.00785 seconds
Memory Before: 559.297 KB
Memory After: 1,640.391 KB
Memory Used: 1,081.094 KB
Time Before: 0.02490 seconds
Time After: 0.02533 seconds
Memory Before: 2,135.344 KB
Memory After: 2,135.961 KB
Time Before: 0.02858 seconds
Time After: 0.02977 seconds
Memory Before: 2,147.523 KB
Memory After: 2,147.383 KB
Time Before: 0.02410 seconds
Time After: 0.03005 seconds
Time Taken: 0.00595 seconds
Memory Before: 2,127.523 KB
Memory After: 2,260.734 KB
Memory Used: 133.211 KB
Time Before: 0.05172 seconds
Time After: 0.05188 seconds
Memory Before: 2,814.250 KB
Memory After: 2,814.766 KB
Time Before: 0.06039 seconds
Time After: 0.06162 seconds
Memory Before: 2,902.586 KB
Memory After: 2,903.180 KB
Time Before: 0.06837 seconds
Time After: 0.06854 seconds
Memory Before: 3,539.344 KB
Memory After: 3,539.773 KB
Time Before: 0.07132 seconds
Time After: 0.07280 seconds
Memory Before: 3,821.078 KB
Memory After: 3,822.766 KB
UPDATE session SET lastactivity = 1785276936, location = '/forums/private.php?do=newpm&explain=1&u=4491' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.09390 seconds
Time After: 0.09420 seconds
Memory Before: 4,299.211 KB
Memory After: 4,299.430 KB
