Time Before: 0.00289 seconds
Time After: 0.00431 seconds
Time Before: 0.00441 seconds
Time After: 0.00481 seconds
Time Before: 0.00506 seconds
Time After: 0.00519 seconds
Time Before: 0.00615 seconds
Time After: 0.00845 seconds
Time Taken: 0.00231 seconds
Time Before: 0.00526 seconds
Time After: 0.01301 seconds
Time Taken: 0.00775 seconds
Time Before: 0.01543 seconds
Time After: 0.01589 seconds
Time Before: 0.01923 seconds
Time After: 0.02069 seconds
Time Before: 0.01473 seconds
Time After: 0.02087 seconds
Time Taken: 0.00614 seconds
Time Before: 0.02833 seconds
Time After: 0.02846 seconds
Time Before: 0.03250 seconds
Time After: 0.03373 seconds
End call of global.php: 0.035364151000977
Time Before: 0.03829 seconds
Time After: 0.03843 seconds
Time Before: 0.04061 seconds
Time After: 0.04207 seconds
SET lastactivity = 1784813965, location = '/forums/private.php?do=newpm&explain=1&u=45029'
Time Before: 0.05479 seconds
Time After: 0.06705 seconds
Time Taken: 0.01226 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.053712129592896 seconds with 9 queries, spending 0.019977331161499 doing MySQL queries and 0.033734798431396 doing PHP things.
