Time Before: 0.02075 seconds
Time After: 0.02615 seconds
Time Taken: 0.00539 seconds
Time Before: 0.02625 seconds
Time After: 0.02668 seconds
Time Before: 0.02693 seconds
Time After: 0.02718 seconds
Time Before: 0.02807 seconds
Time After: 0.03195 seconds
Time Taken: 0.00388 seconds
Time Before: 0.02723 seconds
Time After: 0.03596 seconds
Time Taken: 0.00873 seconds
Time Before: 0.04621 seconds
Time After: 0.04640 seconds
Time Before: 0.04894 seconds
Time After: 0.05018 seconds
Time Before: 0.04552 seconds
Time After: 0.05040 seconds
Time Taken: 0.00488 seconds
Time Before: 0.07961 seconds
Time After: 0.07974 seconds
Time Before: 0.22865 seconds
Time After: 0.22988 seconds
End call of global.php: 0.23266696929932
Time Before: 0.24016 seconds
Time After: 0.24031 seconds
Time Before: 0.24296 seconds
Time After: 0.24439 seconds
SET lastactivity = 1769215693, location = '/forums/private.php?do=newpm&explain=1&u=45032', badlocation = 1
WHERE sessionhash = 'cf9a7d249f143a0ae3eb7b561aa7a27f'
Time Before: 0.26245 seconds
Time After: 0.26273 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.26136898994446 seconds with 9 queries, spending 0.0092151165008545 doing MySQL queries and 0.2521538734436 doing PHP things.
