Time Before: 0.00815 seconds
Time After: 0.01625 seconds
Time Taken: 0.00810 seconds
Time Before: 0.01636 seconds
Time After: 0.01678 seconds
Time Before: 0.01702 seconds
Time After: 0.01746 seconds
Time Before: 0.01834 seconds
Time After: 0.02090 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01752 seconds
Time After: 0.02479 seconds
Time Taken: 0.00727 seconds
Time Before: 0.03274 seconds
Time After: 0.03295 seconds
Time Before: 0.03559 seconds
Time After: 0.03678 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03206 seconds
Time After: 0.03697 seconds
Time Taken: 0.00491 seconds
Memory After: 2,261.719 KB
Time Before: 0.05350 seconds
Time After: 0.05370 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.06837 seconds
Time After: 0.07004 seconds
Time Taken: 0.00167 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.07210898399353
Time Before: 0.07945 seconds
Time After: 0.07962 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.08194 seconds
Time After: 0.08340 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=45103', badlocation = 1
Time Before: 0.10303 seconds
Time After: 0.10340 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.10203409194946 seconds with 9 queries, spending 0.0087029933929443 doing MySQL queries and 0.093331098556519 doing PHP things.
