Time Before: 0.00133 seconds
Time After: 0.00191 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00198 seconds
Time After: 0.00253 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00286 seconds
Time After: 0.00298 seconds
Time Before: 0.00391 seconds
Time After: 0.00680 seconds
Time Taken: 0.00289 seconds
Time Before: 0.00306 seconds
Time After: 0.01153 seconds
Time Taken: 0.00847 seconds
Time Before: 0.01338 seconds
Time After: 0.01380 seconds
Time Before: 0.01618 seconds
Time After: 0.01750 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01274 seconds
Time After: 0.01774 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02462 seconds
Time After: 0.02482 seconds
Time Before: 0.02665 seconds
Time After: 0.02784 seconds
End call of global.php: 0.029575824737549
Time Before: 0.03074 seconds
Time After: 0.03087 seconds
Time Before: 0.03290 seconds
Time After: 0.03443 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=45228'
WHERE sessionhash = 'cb23636bbd36247f3b1133fdf383bca3'
Time Before: 0.04918 seconds
Time After: 0.04947 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
Page generated in 0.048256874084473 seconds with 9 queries, spending 0.0086266994476318 doing MySQL queries and 0.039630174636841 doing PHP things.
