Time Before: 0.02167 seconds
Time After: 0.02742 seconds
Time Taken: 0.00576 seconds
Time Before: 0.02758 seconds
Time After: 0.02800 seconds
Time Before: 0.02823 seconds
Time After: 0.02837 seconds
Time Before: 0.02913 seconds
Time After: 0.03115 seconds
Time Taken: 0.00202 seconds
Time Before: 0.02843 seconds
Time After: 0.03556 seconds
Time Taken: 0.00713 seconds
Time Before: 0.04226 seconds
Time After: 0.04264 seconds
Time Before: 0.04511 seconds
Time After: 0.04635 seconds
Time Before: 0.04152 seconds
Time After: 0.04656 seconds
Time Taken: 0.00504 seconds
Time Before: 0.09012 seconds
Time After: 0.09028 seconds
Time Before: 0.10931 seconds
Time After: 0.11057 seconds
End call of global.php: 0.11275410652161
Time Before: 0.11854 seconds
Time After: 0.11871 seconds
Time Before: 0.12175 seconds
Time After: 0.12324 seconds
SET lastactivity = 1776560416, location = '/forums/private.php?do=newpm&explain=1&u=45350'
Time Before: 0.14429 seconds
Time After: 0.14461 seconds
Memory Before: 4,289.125 KB
Memory After: 4,289.352 KB
Page generated in 0.14315915107727 seconds with 9 queries, spending 0.0076093673706055 doing MySQL queries and 0.13554978370667 doing PHP things.
