Time Before: 0.01270 seconds
Time After: 0.01789 seconds
Time Taken: 0.00518 seconds
Time Before: 0.01800 seconds
Time After: 0.01842 seconds
Time Before: 0.01865 seconds
Time After: 0.01880 seconds
Time Before: 0.01952 seconds
Time After: 0.02183 seconds
Time Taken: 0.00231 seconds
Time Before: 0.01887 seconds
Time After: 0.02613 seconds
Time Taken: 0.00726 seconds
Time Before: 0.03169 seconds
Time After: 0.03203 seconds
Time Before: 0.03390 seconds
Time After: 0.03507 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03113 seconds
Time After: 0.03525 seconds
Time Taken: 0.00412 seconds
Time Before: 0.06246 seconds
Time After: 0.06261 seconds
Time Before: 0.07381 seconds
Time After: 0.07508 seconds
End call of global.php: 0.077174186706543
Time Before: 0.08210 seconds
Time After: 0.08226 seconds
Time Before: 0.08493 seconds
Time After: 0.08639 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=45375', badlocation = 1
Time Before: 0.10559 seconds
Time After: 0.10591 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.10456013679504 seconds with 9 queries, spending 0.007735013961792 doing MySQL queries and 0.096825122833252 doing PHP things.
