Time Before: 0.01572 seconds
Time After: 0.02053 seconds
Time Taken: 0.00480 seconds
Time Before: 0.02060 seconds
Time After: 0.02102 seconds
Time Before: 0.02126 seconds
Time After: 0.02143 seconds
Time Before: 0.02232 seconds
Time After: 0.02439 seconds
Time Taken: 0.00207 seconds
Time Before: 0.02150 seconds
Time After: 0.02810 seconds
Time Taken: 0.00660 seconds
Time Before: 0.03804 seconds
Time After: 0.03872 seconds
Time Taken: 0.00068 seconds
Time Before: 0.04003 seconds
Time After: 0.04134 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03714 seconds
Time After: 0.04153 seconds
Time Taken: 0.00439 seconds
Time Before: 0.06591 seconds
Time After: 0.06605 seconds
Time Before: 0.08521 seconds
Time After: 0.08653 seconds
Time Taken: 0.00132 seconds
Time Before: 0.09979 seconds
Time After: 0.09995 seconds
Time Before: 0.10294 seconds
Time After: 0.10500 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=45506' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.12321 seconds
Time After: 0.12365 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
