Time Before: 0.00142 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00238 seconds
Time Before: 0.00263 seconds
Time After: 0.00275 seconds
Time Before: 0.00369 seconds
Time After: 0.00638 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00282 seconds
Time After: 0.01013 seconds
Time Taken: 0.00731 seconds
Time Before: 0.01199 seconds
Time After: 0.01239 seconds
Time Before: 0.01507 seconds
Time After: 0.01650 seconds
Time Before: 0.01126 seconds
Time After: 0.01676 seconds
Time Taken: 0.00550 seconds
Time Before: 0.02233 seconds
Time After: 0.02247 seconds
Time Before: 0.02458 seconds
Time After: 0.02580 seconds
End call of global.php: 0.02739691734314
Time Before: 0.02879 seconds
Time After: 0.02907 seconds
Time Before: 0.03102 seconds
Time After: 0.03244 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=45691', badlocation = 1
Time Before: 0.04497 seconds
Time After: 0.04539 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.044072866439819 seconds with 9 queries, spending 0.0085477828979492 doing MySQL queries and 0.03552508354187 doing PHP things.
