Time Before: 0.01405 seconds
Time After: 0.01832 seconds
Time Taken: 0.00427 seconds
Time Before: 0.01841 seconds
Time After: 0.01894 seconds
Time Before: 0.01916 seconds
Time After: 0.01931 seconds
Time Before: 0.02037 seconds
Time After: 0.02300 seconds
Time Taken: 0.00263 seconds
Time Before: 0.01937 seconds
Time After: 0.02801 seconds
Time Taken: 0.00864 seconds
Time Before: 0.03390 seconds
Time After: 0.03436 seconds
Time Before: 0.03736 seconds
Time After: 0.03860 seconds
Time Before: 0.03313 seconds
Time After: 0.03878 seconds
Time Taken: 0.00566 seconds
Time Before: 0.06154 seconds
Time After: 0.06170 seconds
Time Before: 0.06920 seconds
Time After: 0.07045 seconds
End call of global.php: 0.07266902923584
Time Before: 0.07756 seconds
Time After: 0.07775 seconds
Time Before: 0.08073 seconds
Time After: 0.08217 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=45734'
Time Before: 0.10015 seconds
Time After: 0.10045 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.098764896392822 seconds with 9 queries, spending 0.0083401203155518 doing MySQL queries and 0.090424776077271 doing PHP things.
