Time Before: 0.02252 seconds
Time After: 0.02957 seconds
Time Taken: 0.00705 seconds
Time Before: 0.02968 seconds
Time After: 0.03018 seconds
Time Before: 0.03039 seconds
Time After: 0.03052 seconds
Time Before: 0.03123 seconds
Time After: 0.03399 seconds
Time Taken: 0.00276 seconds
Time Before: 0.03059 seconds
Time After: 0.03796 seconds
Time Taken: 0.00736 seconds
Time Before: 0.04531 seconds
Time After: 0.04569 seconds
Time Before: 0.04815 seconds
Time After: 0.04938 seconds
Time Before: 0.04465 seconds
Time After: 0.04959 seconds
Time Taken: 0.00495 seconds
Time Before: 0.09953 seconds
Time After: 0.09966 seconds
Time Before: 0.28073 seconds
Time After: 0.28194 seconds
End call of global.php: 0.28408098220825
Time Before: 0.29064 seconds
Time After: 0.29078 seconds
Time Before: 0.29295 seconds
Time After: 0.29441 seconds
SET lastactivity = 1783063128, location = '/forums/private.php?do=newpm&explain=1&u=45753'
Time Before: 0.31279 seconds
Time After: 0.31770 seconds
Time Taken: 0.00491 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.31172800064087 seconds with 9 queries, spending 0.012864589691162 doing MySQL queries and 0.29886341094971 doing PHP things.
