Time Before: 0.01512 seconds
Time After: 0.01921 seconds
Time Taken: 0.00409 seconds
Time Before: 0.01931 seconds
Time After: 0.01971 seconds
Time Before: 0.01996 seconds
Time After: 0.02014 seconds
Time Before: 0.02099 seconds
Time After: 0.02319 seconds
Time Taken: 0.00220 seconds
Time Before: 0.02020 seconds
Time After: 0.02733 seconds
Time Taken: 0.00713 seconds
Time Before: 0.03230 seconds
Time After: 0.03283 seconds
Time Taken: 0.00053 seconds
Time Before: 0.03418 seconds
Time After: 0.03534 seconds
Time Taken: 0.00115 seconds
Time Before: 0.03162 seconds
Time After: 0.03554 seconds
Time Taken: 0.00392 seconds
Time Before: 0.06027 seconds
Time After: 0.06041 seconds
Time Before: 0.07030 seconds
Time After: 0.07162 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.073847055435181
Time Before: 0.07889 seconds
Time After: 0.07904 seconds
Time Before: 0.08131 seconds
Time After: 0.08280 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=45800'
Time Before: 0.09999 seconds
Time After: 0.10031 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.098641872406006 seconds with 9 queries, spending 0.0078811645507812 doing MySQL queries and 0.090760707855225 doing PHP things.
