Time Before: 0.00152 seconds
Time After: 0.00210 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00217 seconds
Time After: 0.00251 seconds
Time Before: 0.00271 seconds
Time After: 0.00287 seconds
Time Before: 0.00354 seconds
Time After: 0.00573 seconds
Time Taken: 0.00220 seconds
Time Before: 0.00292 seconds
Time After: 0.00910 seconds
Time Taken: 0.00619 seconds
Time Before: 0.01134 seconds
Time After: 0.01180 seconds
Time Before: 0.01425 seconds
Time After: 0.01542 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01071 seconds
Time After: 0.01560 seconds
Time Taken: 0.00489 seconds
Time Before: 0.02052 seconds
Time After: 0.02078 seconds
Time Before: 0.02267 seconds
Time After: 0.02395 seconds
Time Before: 0.02683 seconds
Time After: 0.02697 seconds
Time Before: 0.02889 seconds
Time After: 0.03030 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=45813' WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.04275 seconds
Time After: 0.04307 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
