Time Before: 0.00706 seconds
Time After: 0.01018 seconds
Time Taken: 0.00312 seconds
Time Before: 0.01029 seconds
Time After: 0.01070 seconds
Time Before: 0.01100 seconds
Time After: 0.01113 seconds
Time Before: 0.01207 seconds
Time After: 0.01424 seconds
Time Taken: 0.00217 seconds
Time Before: 0.01121 seconds
Time After: 0.01864 seconds
Time Taken: 0.00743 seconds
Time Before: 0.02252 seconds
Time After: 0.02293 seconds
Time Before: 0.02547 seconds
Time After: 0.02669 seconds
Time Before: 0.02171 seconds
Time After: 0.02694 seconds
Time Taken: 0.00523 seconds
Time Before: 0.04233 seconds
Time After: 0.04249 seconds
Time Before: 0.05050 seconds
Time After: 0.05182 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.054145097732544
Time Before: 0.06009 seconds
Time After: 0.06027 seconds
Time Before: 0.06336 seconds
Time After: 0.06485 seconds
SET lastactivity = 1788922094, location = '/forums/private.php?do=newpm&explain=1&u=4585'
Time Before: 0.08408 seconds
Time After: 0.08450 seconds
Memory Before: 4,911.164 KB
Memory After: 4,911.383 KB
Page generated in 0.083029985427856 seconds with 9 queries, spending 0.0079240798950195 doing MySQL queries and 0.075105905532837 doing PHP things.
