Time Before: 0.02449 seconds
Time After: 0.03522 seconds
Time Taken: 0.01073 seconds
Time Before: 0.03534 seconds
Time After: 0.03580 seconds
Time Before: 0.03606 seconds
Time After: 0.03618 seconds
Time Before: 0.03698 seconds
Time After: 0.03895 seconds
Time Taken: 0.00197 seconds
Time Before: 0.03625 seconds
Time After: 0.04316 seconds
Time Taken: 0.00692 seconds
Time Before: 0.05523 seconds
Time After: 0.05569 seconds
Time Before: 0.05833 seconds
Time After: 0.05954 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.05438 seconds
Time After: 0.05981 seconds
Time Taken: 0.00543 seconds
Memory After: 2,261.836 KB
Time Before: 0.09565 seconds
Time After: 0.09581 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.11882 seconds
Time After: 0.12004 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.12240505218506
Time Before: 0.13163 seconds
Time After: 0.13179 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.13435 seconds
Time After: 0.13583 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788890195, location = '/forums/private.php?do=newpm&explain=1&u=45901', badlocation = 1
Time Before: 0.15810 seconds
Time After: 0.15860 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.15698099136353 seconds with 9 queries, spending 0.0077440738677979 doing MySQL queries and 0.14923691749573 doing PHP things.
