Time Before: 0.01087 seconds
Time After: 0.01451 seconds
Time Taken: 0.00364 seconds
Time Before: 0.01463 seconds
Time After: 0.01512 seconds
Time Before: 0.01537 seconds
Time After: 0.01551 seconds
Time Before: 0.01635 seconds
Time After: 0.01891 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01557 seconds
Time After: 0.02318 seconds
Time Taken: 0.00761 seconds
Time Before: 0.02846 seconds
Time After: 0.02907 seconds
Time Taken: 0.00060 seconds
Time Before: 0.03155 seconds
Time After: 0.03283 seconds
Time Before: 0.02777 seconds
Time After: 0.03311 seconds
Time Taken: 0.00534 seconds
Time Before: 0.05356 seconds
Time After: 0.05375 seconds
Time Before: 0.06310 seconds
Time After: 0.06439 seconds
Time Before: 0.07330 seconds
Time After: 0.07348 seconds
Time Before: 0.07662 seconds
Time After: 0.07810 seconds
UPDATE session SET lastactivity = 1784760425, location = '/forums/private.php?do=newpm&explain=1&u=45903', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.09697 seconds
Time After: 0.09727 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
