Time Before: 0.00143 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00243 seconds
Time Before: 0.00270 seconds
Time After: 0.00285 seconds
Time Before: 0.00349 seconds
Time After: 0.00581 seconds
Time Taken: 0.00232 seconds
Time Before: 0.00289 seconds
Time After: 0.00937 seconds
Time Taken: 0.00648 seconds
Time Before: 0.01169 seconds
Time After: 0.01202 seconds
Time Before: 0.01415 seconds
Time After: 0.01528 seconds
Time Taken: 0.00113 seconds
Time Before: 0.01106 seconds
Time After: 0.01555 seconds
Time Taken: 0.00449 seconds
Time Before: 0.02152 seconds
Time After: 0.02180 seconds
Time Before: 0.02349 seconds
Time After: 0.02471 seconds
Time Before: 0.02727 seconds
Time After: 0.02751 seconds
Time Before: 0.02942 seconds
Time After: 0.03088 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=45912' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04330 seconds
Time After: 0.04353 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
