Time Before: 0.00126 seconds
Time After: 0.00170 seconds
Time Before: 0.00177 seconds
Time After: 0.00215 seconds
Time Before: 0.00238 seconds
Time After: 0.00251 seconds
Time Before: 0.00342 seconds
Time After: 0.00590 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00260 seconds
Time After: 0.00932 seconds
Time Taken: 0.00671 seconds
Time Before: 0.01116 seconds
Time After: 0.01161 seconds
Time Before: 0.01501 seconds
Time After: 0.01620 seconds
Time Before: 0.01044 seconds
Time After: 0.01638 seconds
Time Taken: 0.00593 seconds
Time Before: 0.02124 seconds
Time After: 0.02136 seconds
Time Before: 0.02326 seconds
Time After: 0.02456 seconds
End call of global.php: 0.027237176895142
Time Before: 0.02945 seconds
Time After: 0.02987 seconds
Time Before: 0.03281 seconds
Time After: 0.03422 seconds
SET lastactivity = 1788883453, location = '/forums/private.php?do=newpm&explain=1&u=45925', badlocation = 1
Time Before: 0.04819 seconds
Time After: 0.04847 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.047260999679565 seconds with 9 queries, spending 0.0081415176391602 doing MySQL queries and 0.039119482040405 doing PHP things.
