Time Before: 0.00137 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00233 seconds
Time Before: 0.00253 seconds
Time After: 0.00266 seconds
Time Before: 0.00355 seconds
Time After: 0.00739 seconds
Time Taken: 0.00384 seconds
Time Before: 0.00274 seconds
Time After: 0.01311 seconds
Time Taken: 0.01037 seconds
Time Before: 0.01494 seconds
Time After: 0.01584 seconds
Time Taken: 0.00090 seconds
Time Before: 0.01847 seconds
Time After: 0.01976 seconds
Time Before: 0.01430 seconds
Time After: 0.02002 seconds
Time Taken: 0.00572 seconds
Time Before: 0.02554 seconds
Time After: 0.02570 seconds
Time Before: 0.02746 seconds
Time After: 0.02875 seconds
Time Before: 0.03298 seconds
Time After: 0.03318 seconds
Time Before: 0.03523 seconds
Time After: 0.03665 seconds
UPDATE session SET lastactivity = 1789088167, location = '/forums/private.php?do=newpm&explain=1&u=45963' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04897 seconds
Time After: 0.04946 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
