Time Before: 0.00168 seconds
Time After: 0.00224 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00232 seconds
Time After: 0.00288 seconds
Time Before: 0.00312 seconds
Time After: 0.00326 seconds
Time Before: 0.00400 seconds
Time After: 0.00690 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00331 seconds
Time After: 0.01147 seconds
Time Taken: 0.00816 seconds
Time Before: 0.01327 seconds
Time After: 0.01352 seconds
Time Before: 0.01600 seconds
Time After: 0.01729 seconds
Time Before: 0.01270 seconds
Time After: 0.01757 seconds
Time Taken: 0.00487 seconds
Time Before: 0.02475 seconds
Time After: 0.02493 seconds
Time Before: 0.02754 seconds
Time After: 0.02898 seconds
Time Before: 0.03394 seconds
Time After: 0.03412 seconds
Time Before: 0.03744 seconds
Time After: 0.03897 seconds
Time Taken: 0.00153 seconds
UPDATE session SET lastactivity = 1783125292, location = '/forums/private.php?do=newpm&explain=1&u=46001', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.05331 seconds
Time After: 0.05366 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
