Time Before: 0.00217 seconds
Time After: 0.00290 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00302 seconds
Time After: 0.00369 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00398 seconds
Time After: 0.00411 seconds
Time Before: 0.00479 seconds
Time After: 0.00699 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00416 seconds
Time After: 0.01043 seconds
Time Taken: 0.00627 seconds
Time Before: 0.01225 seconds
Time After: 0.01267 seconds
Time Before: 0.01509 seconds
Time After: 0.01632 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01164 seconds
Time After: 0.01655 seconds
Time Taken: 0.00491 seconds
Memory After: 2,261.719 KB
Time Before: 0.02300 seconds
Time After: 0.02311 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02534 seconds
Time After: 0.02656 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.02982 seconds
Time After: 0.02995 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03184 seconds
Time After: 0.03322 seconds
Time Taken: 0.00139 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=46012', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04559 seconds
Time After: 0.04590 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
