Time Before: 0.01535 seconds
Time After: 0.02099 seconds
Time Taken: 0.00565 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02111 seconds
Time After: 0.02178 seconds
Time Taken: 0.00066 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02208 seconds
Time After: 0.02227 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02326 seconds
Time After: 0.02578 seconds
Time Taken: 0.00252 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02237 seconds
Time After: 0.02999 seconds
Time Taken: 0.00762 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03845 seconds
Time After: 0.03884 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04114 seconds
Time After: 0.04244 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.03777 seconds
Time After: 0.04267 seconds
Time Taken: 0.00490 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.07349 seconds
Time After: 0.07367 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.11815 seconds
Time After: 0.11941 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.14589 seconds
Time After: 0.14610 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.15047 seconds
Time After: 0.15196 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1772779868, location = '/forums/private.php?do=newpm&explain=1&u=46089' WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.17469 seconds
Time After: 0.17493 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
