Time Before: 0.00159 seconds
Time After: 0.00221 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00228 seconds
Time After: 0.00283 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00308 seconds
Time After: 0.00321 seconds
Time Before: 0.00392 seconds
Time After: 0.00628 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00326 seconds
Time After: 0.01214 seconds
Time Taken: 0.00888 seconds
Time Before: 0.01501 seconds
Time After: 0.01542 seconds
Time Before: 0.01809 seconds
Time After: 0.01936 seconds
Time Before: 0.01424 seconds
Time After: 0.01963 seconds
Time Taken: 0.00539 seconds
Time Before: 0.02787 seconds
Time After: 0.02801 seconds
Time Before: 0.03035 seconds
Time After: 0.03162 seconds
End call of global.php: 0.033811092376709
Time Before: 0.03502 seconds
Time After: 0.03521 seconds
Time Before: 0.03722 seconds
Time After: 0.03868 seconds
SET lastactivity = 1785412628, location = '/forums/private.php?do=newpm&explain=1&u=4609'
Time Before: 0.05264 seconds
Time After: 0.05294 seconds
Memory Before: 4,288.281 KB
Memory After: 4,288.500 KB
Page generated in 0.051692008972168 seconds with 9 queries, spending 0.0080699920654297 doing MySQL queries and 0.043622016906738 doing PHP things.
