Time Before: 0.00242 seconds
Time After: 0.00307 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00316 seconds
Time After: 0.00361 seconds
Time Before: 0.00382 seconds
Time After: 0.00396 seconds
Time Before: 0.00468 seconds
Time After: 0.00689 seconds
Time Taken: 0.00220 seconds
Time Before: 0.00401 seconds
Time After: 0.01036 seconds
Time Taken: 0.00635 seconds
Time Before: 0.01230 seconds
Time After: 0.01272 seconds
Time Before: 0.01592 seconds
Time After: 0.01726 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01164 seconds
Time After: 0.01747 seconds
Time Taken: 0.00583 seconds
Time Before: 0.02311 seconds
Time After: 0.02334 seconds
Time Before: 0.02523 seconds
Time After: 0.02647 seconds
Time Before: 0.02949 seconds
Time After: 0.02964 seconds
Time Before: 0.03167 seconds
Time After: 0.03387 seconds
UPDATE session SET lastactivity = 1782929758, location = '/forums/private.php?do=newpm&explain=1&u=46164', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04710 seconds
Time After: 0.04737 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
