Time Before: 0.00627 seconds
Time After: 0.01014 seconds
Time Taken: 0.00386 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.01025 seconds
Time After: 0.01064 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.01087 seconds
Time After: 0.01100 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.01182 seconds
Time After: 0.01402 seconds
Time Taken: 0.00220 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.01105 seconds
Time After: 0.01843 seconds
Time Taken: 0.00738 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.02372 seconds
Time After: 0.02416 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.02555 seconds
Time After: 0.02674 seconds
Memory Before: 2,148.203 KB
Memory After: 2,148.063 KB
Time Before: 0.02305 seconds
Time After: 0.02694 seconds
Time Taken: 0.00389 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.086 KB
Time Before: 0.04153 seconds
Time After: 0.04166 seconds
Memory Before: 2,814.633 KB
Memory After: 2,815.148 KB
Time Before: 0.05152 seconds
Time After: 0.05277 seconds
Memory Before: 2,902.938 KB
Memory After: 2,903.531 KB
End call of global.php: 0.055078983306885
Time Before: 0.05958 seconds
Time After: 0.05975 seconds
Memory Before: 3,539.703 KB
Memory After: 3,540.133 KB
Time Before: 0.06205 seconds
Time After: 0.06353 seconds
Memory Before: 3,821.234 KB
Memory After: 3,822.922 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=46174'
Time Before: 0.08163 seconds
Time After: 0.08203 seconds
Memory Before: 4,294.844 KB
Memory After: 4,295.086 KB
Page generated in 0.080513000488281 seconds with 9 queries, spending 0.0077953338623047 doing MySQL queries and 0.072717666625977 doing PHP things.
