Time Before: 0.00828 seconds
Time After: 0.01221 seconds
Time Taken: 0.00394 seconds
Time Before: 0.01229 seconds
Time After: 0.01280 seconds
Time Before: 0.01306 seconds
Time After: 0.01322 seconds
Time Before: 0.01395 seconds
Time After: 0.01727 seconds
Time Taken: 0.00331 seconds
Time Before: 0.01328 seconds
Time After: 0.02203 seconds
Time Taken: 0.00875 seconds
Time Before: 0.02607 seconds
Time After: 0.02658 seconds
Time Before: 0.02922 seconds
Time After: 0.03045 seconds
Time Before: 0.02538 seconds
Time After: 0.03071 seconds
Time Taken: 0.00534 seconds
Time Before: 0.05159 seconds
Time After: 0.05175 seconds
Time Before: 0.06192 seconds
Time After: 0.06332 seconds
Time Taken: 0.00140 seconds
End call of global.php: 0.065519094467163
Time Before: 0.07011 seconds
Time After: 0.07028 seconds
Time Before: 0.07299 seconds
Time After: 0.07449 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1789042258, location = '/forums/private.php?do=newpm&explain=1&u=46240'
Time Before: 0.09106 seconds
Time After: 0.09139 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.089927911758423 seconds with 9 queries, spending 0.0092751979827881 doing MySQL queries and 0.080652713775635 doing PHP things.
